I have a Kubota B2650 with backhoe. I hadthe dealer add the third function for a grapple. The dealer set it up so that I have to use the backhoe connections to run the grapple. If I want to use the grapple and the backhoe at the same time, I have to connect all of the hoses together. It is also causing mechanical wear on one hose jacket; I can't seem to get the hose for the grapple connected in such a way avoid the lift arm when using the box blade/tiller.
I was told there is no way to set this up. I can't believe there isn't a cleaner way of hook this up. I am hoping someone will have some experience with this stuff.
Any help or suggestions would be appreciated.
Randy
Randy
