Kubota B2400HSD Hydraulics Issue
   / Kubota B2400HSD Hydraulics Issue #1
PDAJay
Pelzer, SC
Kubota B2400
Okay, backstory on problem.....
Pressure line going to power steering pump developed a crack, since the previous owner had brazed it (badly) before, I had to have my local hydraulics place make a replacement for me.
Get home, get everything installed and fire the tractor up. Discovered quite quickly that I had not tightened the hydraulic pump fitting (oops). Shut down engine, tightened fitting and cranked back up.
Go through bleeding procedure, seems very stiff. Try front loader, nothing.
Check flow control and it is fully open. Fluid level is good.
Lower 3ph and then try to raise it back up, no go.
Tractor will move forward and backwards without issue (other than dragging front loader bucket on concrete).
Any ideas on what I should try next?
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2015 FREIGHTLINER...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
1996 Elgin Pelican Series S Street Sweeper (A53421)
1996 Elgin Pelican...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
