kubota b2400 pto not dis-engaging
   / kubota b2400 pto not dis-engaging #1
mdproducts
California
Kubota b2400
I just purchased a used b2400 w/ loader and have now found out that the pto will not dis-engage. Also the saftey switch has been bypassed so the tractor will start. Any thoughts on how to fix (besides the obvious: why didn't you check this before you purchased offroadfab@yahoo.com )
thanks!
   / kubota b2400 pto not dis-engaging #2
You didn't specify whether it was the mid or rear pto, either way you might look at where the shift lever attaches to the shaft near the trans housing and see if by chance a roll pin fell out. When you attempt to disengage does it feel like it's pulling on the shift fork? Or does the lever move back and forth freely?
The rear pto will not dis-engage. The belly mounted pto will engage and dis-engage with no problem.
thanks for your help..
Sorry, I don't think I replied to the right person, your help is still needed.... The rear pto will not dis-engage. The belly mounted pto will engage and dis-engage with no problem. To be honest with you, it feels like it is engaging and dis-engaging when you cycle the "lever".
Any imput would be great.
   / kubota b2400 pto not dis-engaging #5
Does the pto stop spinning when you push in the clutch pedal?
Does the pto control lever move through all of its travel?
Is there any rattling noise while moving the control lever through it travel?
Does the lever move smoothly?
Do you have a parts book or a parts PDF file? You can get one on line at Tractorsmart.com. That's where I got mine.
MALONE 3000TP LOT NUMBER 229 (A53084)
MALONE 3000TP LOT...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2008 FORD F-350 (A52472)
2008 FORD F-350...
2013 John Deere 824K (A53472)
2013 John Deere...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
