Kubota B2400 PTO does not engage
   / Kubota B2400 PTO does not engage #1
cafsman
Grundy, Illinois
Kubota 2400
Just changed out the HST transmission which was a royal PITA and now neither one of the PTO engages? Did not touch anything on the rear differential and they were both working before. I can depress the clutch fully and the input shaft stops rotating, shift the 540 PTO into "engaged position" and NOTHING. Same with the front 2400 PTO. I am stymied!!!:mad:
   / Kubota B2400 PTO does not engage #2
Do you fix the problem? What was,it?
   / Kubota B2400 PTO does not engage #3
I have a B2100 and just changed out the hydrostatic transmission. Both PTO shafts will not turn also. Did you come up with a solution to fix yours?
   / Kubota B2400 PTO does not engage #4
Almost looks like it may be missing a splined coupler between the HST and PTO input shaft.
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
Unused Delta Crash...
2018 Jaguar XE Sedan (A50324)
2018 Jaguar XE...
2015 Chevrolet Express Shuttle Bus (A50323)
2015 Chevrolet...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
2010 Astec Underground RT660 4WD Trencher (A50322)
2010 Astec...
