kubota b2400 hydrostatic problems
   / kubota b2400 hydrostatic problems #1
jcullers4
Need some help here. I have a 1500 hour B2400 HST. Here is whats going on. All the hydraulic functions work perfectly including the FEL and the 3 point. In REVERSE the power is completely normal. Put it against a tree in reverse and she'll spin all four no problem. The problem is VERY LOW POWER IN FORWARD. It will pull itself in low range but will not climb very much of an incline or obstacle. In high range it will barely try to pull itself on flat ground, goes normal on a down hill, and you can forget it on any kind of incline. Hydraulic fluid and filter have been replaced this morning but the problem persists. Any suggestions.
Edit/Delete Message:confused:
   / kubota b2400 hydrostatic problems #2
I'm not sure what's it called but I recall the service rep telling me about it (he was kinda bragging that Kubota sends more power to the steering when compared to JD to make it easier on the operator). It's a sort of manifold valve that controls how much fluid goes to which function (i.e. forward, reverse, power steering). Sounds like it's not diverting flow to forward function. Good luck...
thanks. Thats a start. I'll see what i can finnd out.
   / kubota b2400 hydrostatic problems #4
This sounds more like a pressure relief valve problem with the hydro circuit. The priority valve only controls hydraulic oil for power steering (approx 1.6 gpm) and then the remainder to the fel and 3ph. The hydro uses a seperate circuit that's internal which includes a charge pump, the radial pump and driven radial motor. As I recall, the forward and reverse each has it's own relief circuit and this is where I'd begin.
   / kubota b2400 hydrostatic problems #5
Swapping the fwd/rev high pressure relief valves would be a good start. If it changes it to having power in fwd and no power in rev then it is a simple as replacing a relief valve, if nothing changes then it is likely a deeper internal issue.
Brian
Ok. So I swapped the forward/reverse high pressure relief valves and am still having the same problem. Could there be a problem with the seat for the forward valve? I appreciate the help so far. Any other suggestions? I've been studying the service diagrams and can't figure out what else could be causing this without affecting anything else.
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
50 CAT 5 TOOTH EXCAVATOR BUCKET (A50854)
50 CAT 5 TOOTH...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
