Kubota b2100
   / Kubota b2100 #1
heyu
qc.
kubota b2100
Hi Folks
question today is about hard steering on right side only , both turning from center to stop and back to center. left side is fine
Kubota b2100 with bispeed not on. what do you think. I only have operators manual at this time. app.750 hrs. Ken
   / Kubota b2100 #2
Hi Folks
I have a very similar machine (B1700D)
need more info...how long have you had the tractor?...any other issues, leaks etc.? how is the 4WD ? (is this what you mean by "bispeed"?) tire wear etc. etc...
   / Kubota b2100
Hi Slash Pine
tractor has power steering with bispeed turn. 4wd works fine ,3pth is ok ,I have a front mt sno blower not on now but the
blower mount frame is still on and hyd for that is fine tires are ok [ turfs] and are proper size frt and rear . someone told me that water may run in top of box but I have a cab on all winter and summer time always parked under cover anyway this only started late in febuary. Ken I have had tractor 7 yrs
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
2008 CATERPILLAR 320D L (A50854)
2008 CATERPILLAR...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
1994 Toyota 6000lbs 2 Stage Forklift (A51039)
1994 Toyota...
