Kubota B2100 Loader hydraulic Valve block leaks
   / Kubota B2100 Loader hydraulic Valve block leaks #1
jrboss
Kubota B2100 HSD
I have a 99 Kubota B2100 with 1500 hours ... the loader is well used, but still works great. The issue - the valve block has started leaking, it leaks at the spring end of one of the carriers (if that is what they are called) ... should there even be fluid in that area? The quick connects also leak when wiggled. I'm trying to figure out the best way to solve the leaks ... I'm tired of cleaning the grassy sludge off the top of my mover deck and floor of my shed. Side Note: the bucket also drops slowly when left in one place, I think this is an indication that there is an internal leak ... I'm not too worried about it, but I think it may be a sign the valves are pretty worn.
4 BRIDGESTONE 11R24.5 (A50854)
4 BRIDGESTONE...
2015 FORD F350 SERVICE TRUCK (A51222)
2015 FORD F350...
2015 PETERBILT CLASS 8 CEMENT MIXER TRUCK (A51243)
2015 PETERBILT...
377811 (A48836)
377811 (A48836)
Allied 760 Loader (A50515)
Allied 760 Loader...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A49461)
2021 Caterpillar...
