A FRIEND OF MINE HAS A B21 WITH FEL AND BACKHOE.
I LIKE THE SIZE OF THIS TRACTOR BUT I DON'T NEED THE BACKHOE OR THE FEL. DOES ANY ONE KNOW IF YOU CAN BUY JUST THE BARE TRACTOR ??? ALL THE ONE'S I HAVE FOUND HAVE THE FEL. OR DO I HAVE TO LOOK AT ANOTHER MODEL??
THANK'S WOODY
WoodyTree
You've found the right place to start/w3tcompact/icons/smile.gif Try also.. http://www.tractorbynet.com/book/index.shtml http://www.carverequipment.com/
And if that's not enough readin'/w3tcompact/icons/wink.gif there's a lot of info. from the other brands, I'm sure you'll get more leads.
regards
Mutt
HI,
B21s are tractor - loaders
or tractor loader backhoes
Not just tractors...
the loader is very hd and not made to detach.
The B21 doesn't have mid pto.. and does have min. space under the tractor-- so you will not be able to use a mid mount mower with it.
If it's a very good deal... buy the B21 and trade it in on a BX,B7500,B2710,B2910.. you'll probably be able to end up with a great value.
Also.. we have some extra backhoes to fit the B21s $3900 and up.
I'm sure you could, but I don't know why you would want to. The B21 is a point design intended for back hoe and loader. If you remove the loader and back hoe you have a tractor with no mid PTO, limited three point hitch HP (I recall 13) at probably a price premium.
I would look at other models and makes. Figure out what you plan to do for now and in the foreseeable future and go from there.
A backhoe I put in the luxury catagory the front loader in the gotta have catagory.
Al
