kubota B21
   / kubota B21 #1
Clarkschapel
Huntington, AR
B21 kubota
Need help Please, I have a B21 Kubota Diesel tractor and when I start turning the engine over it fires up and then stops running like its out of fuel. changed the fuel filter out did not help, could it be because i have a tube on my fuel injection pump that is leaking, tried to find part number for that and have not been able to do so. Any suggestions would be helpful thanks Clark.
   / kubota B21 #2
Check the fuse for the shut-off solenoid. The solenoid is energized with the "start" position and then held open with the "run" position. If the fuse fails the engine will start with available fuel then quickly dye since no more fuel is being supplied.
If the fuse is good then test the solenoid.
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A51039)
2016 KBH...
2013 Acura RDX AWD SUV (A48082)
2013 Acura RDX AWD...
2019 Ford Explorer AWD SUV (A48082)
2019 Ford Explorer...
