Tinman236
Hello Hydraulic Masters, I am trying to convert the manually operated chute rotator and deflector on a RADTECH Blizzard B64 3pt PTO snow blower. I suppose I could use a 12v electric actuator for the chute deflector and a 12v gear reduced motor chute rotation, but I would prefer to use hydraulics. After I drop the backhoe in order to set up the 3 pt hitch, I must couple the supply and return lines that powered the BH to themselves and close an internal valve which then allows the 3 pt to operate. If possible, I must get fluid to a double spool valve to control two cylinders at the SB. I am not sure about Kubota's design, but I have heard the term "closed system or closed loop" mentioned. There are no remote hydraulic couplers like some of the newer larger models. Proper design and operation is a must as I do not want to damage the HST pump which drives the tractor. I would appreciate opinions from experienced hydraulic techs or those who know the Kubota B21 TLB fluid system. Thanx for understanding my project. Tinman236
