Kubota B21 - Difficult To Start
   / Kubota B21 - Difficult To Start #1
Whitey
Slippery Rock, Pennsylvania
Kabota B21 TLB
Another post about a tough to start Kubota. I have a 2005 Kubota B21 with 350 hours on it. Lately when I go to start it I turn the key and nothing. This has been going on for some time........albeit on and off.
All I have to do is lean over and cross the solenoid and boom she starts.
This is becoming a habit lately and I want to fix it.
I believe it is one of the two safeties that are in-line with the ignition.........one at the clutch and one at the PTO engagement lever.
Has anyone ever taken these apart to clean them?? I have heard (through the grapevine) that the corrode after time and do not engage within their housing.
Or.........can anyone give me direction on how to at least check the ignition to start there.
   / Kubota B21 - Difficult To Start #2
Use a Digital Volt Ohm Meter... Measure across the switches, one at a time... You will easily find the one with high resistance...
You can use the Ohms setting of the meter without applying power across the switch, OR the volts DC setting With power applied to find where the voltage is being dropped.
Thanks KennyV........that will be on the list for this weekend!
   / Kubota B21 - Difficult To Start #4
Also check the treddle safety switch, this is the switch which requires the forward/backward pedel be in the nutural position in case both the clutch and PTO switch check out
45019 (A48082)
45019 (A48082)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
2022 Wacker Neuson LTV6 S/A Towable Light Tower (A49346)
2022 Wacker Neuson...
10ft x 8ft Container with Side Door (A48837)
10ft x 8ft...
377937 (A48837)
377937 (A48837)
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A50046)
2003 FONTAINE...
