kubota B21 Battery not keeping charge
   / kubota B21 Battery not keeping charge #1
Clarkschapel
Huntington, AR
B21 kubota
The lights are not working on the tractor, just wondering if i might have a short in the system that is draining the battery, I can jump start the tractor and it runs just fine. the battery was purchased in 2014, i check the battery for water and it was ok. just not sure where to start looking for a ground or short in the system, i am wondering about the light switch selector. does anyone have a schematic of the electrical system on this B21. thank you for any input on this
   / kubota B21 Battery not keeping charge #2
Disconnect the battery after shutting tractor off. If it's good the next day start looking at the light system wiring.
   / kubota B21 Battery not keeping charge #3
I had a similar problem with my Ford 1210. Turned out to be some dirt or corrosion in a plug connection. Battery and alternator were fine. Cleaning the connection did the trick.
thanks for the help, ill check those out next chance i get.
   / kubota B21 Battery not keeping charge #5
Does the charging lamp illuminate when the ignition switch is turned on? Does the charging lamp extinguish when the engine is running?
   / kubota B21 Battery not keeping charge #6
If your lights don't work, replace that fuse first as it also supplies the instrument cluster and also supplies the alt charge lamp which supplies power to excite the alternator.
I will take a look at that as soon as i can, thank you for your help, I will let you know what i find out.
   / kubota B21 Battery not keeping charge #8
A tractor or vehicle with a working alternator can run after being started without a battery. This reminds me of a story. The alternator on my dads truck went out. The battery was soon depleted, and the truck died. It was on a bad stretch of road about 20 miles from home. He called a family member to bring us a generator, extension cord, and a battery charger. You can probably figure out what we did from this point.
2025 Kivel Quick Hitch Skid Steer Attachment (A49346)
2025 Kivel Quick...
2015 Ford F-250 Pickup Truck (A48081)
2015 Ford F-250...
(3) Goodyear 10R 22.5 Tires (A48837)
(3) Goodyear 10R...
2018 VOLVO ECR88D EXCAVATOR (A50458)
2018 VOLVO ECR88D...
2000 Volvo VNL Truck, VIN # 4V4N21JF7YN250153 (A48836)
2000 Volvo VNL...
2024 CATERPILLAR 289D3 SKID STEER (A50458)
2024 CATERPILLAR...
