Kubota B1700HD 3-point issue - please help
   / Kubota B1700HD 3-point issue - please help #1
BParks
Fenton, MI
Kubota B1700
The 3-point on my Kubota B1700HD is not working properly. I was pushing snow and noticed that the lever was becoming difficult to move upward to lift the 3-point. It eventually stopped lifting altogether. I discovered a leak in the control valve for the front loader (no loader attached); which lead me to check the hydraulic fluid level which was low. I replaced all the fluid, cleaned the screen, and changed the filter. The 3-point, now, does not start to lift until the lever is pulled about セ of the way up. From there, minor movements in the lever cause it to lift rapidly. With the lever pulled fully upward, the 3-point lifts about セ of its normal height. Does anyone have any suggestions on diagnosing this issue?
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
Upright SL-200 Scissor Lift (A50121)
Upright SL-200...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
New Holland 479 Haybine (A50774)
New Holland 479...
Feteral 10"x60' Transport Auger (A50774)
Feteral 10"x60'...
