kubota b 6000
   / kubota b 6000 #1
xmoikan
i have a kubota b6000 with 13 hp diesel power motor
i'm planning to built a frond loader and i wondering about the hydraylics
1-my oil pump i think can press almost 20lt/min, so can the pump afford a set of hydraylic actuators?
2- what kind of actuators should i find?
sorry for my english but i dont know well rhe teqhnical words
   / kubota b 6000 #2
:cool:Hi, and welcome to our site. I have put a FEL on my B7100HST and it is pretty similar to your tractor I do believe. If you would like to see how I did it,go to search on the top of this page, click on it and enter my screen name. It will show you the threads I have on here. Hope it helps you. If you want to ask any questions , you can email me at zman007007@aol.com zman007007
   / kubota b 6000 #3
You can add many attachments to a tractor that has hydraulics. The pump is sized for the tractor, by how much HP is available to run the pump and power the tractor. I suspect your pump is not very large, because, a 13 HP engine running at 2500 rpm, can turn a pump with a displacement of .6 cu in, and pump 7.5 GPM at 2500 psi, at idle. Otherwise, all available HP is going to run the pump. So, whatever your pump can pump in GPM, at a certain psi, you can then install a small FEL, and power those cylinders with whatever you have. The amount of pressure, and size of the cylinders is what gives the force. The GPM rating determines the speed of the cylinders.
2013 Ford Explorer SUV (A51694)
2013 Ford Explorer...
Case CX80C (A50123)
Case CX80C (A50123)
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2016 Arising 8.520VTRW 22ft T/A Enclosed Cargo Trailer (A51694)
2016 Arising...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
2011 Wacker Neuson RD12A, 36" Double Drum Roller (A52384)
2011 Wacker Neuson...
