Kubota B 2910
   / Kubota B 2910 #1
Anonymous Poster
Epic Contributor
Will a B 2910 pull a 6 ft bushog or should we get a 5 ft?? Going to cut weeds and light brush.
   / Kubota B 2910 #2
ducky
Welcome to TBN. /w3tcompact/icons/smile.gif
I have a 5’ <font color=green>JD</font color=green> Rotary Cutter for my 2910. When the weeds are high (over 2’) and heavy I have use low range to cut 3 acres of field. Engine will start to lug down at times and I have to let off HST pedal until rpm’s pickup again.
I run in mid range when weeds are 1’ or less. Engine will not lug down even at full HST speed.
The height and type of field you are cutting will determine what speed and size of rotary cutter you can handle with a 2910.
In the 2910 manual <font color=orange>KUBOTA</font color=orange> recommends a 48” rotary cutter weighing 500 lbs. My 513's weight is 508 lbs.
There are many discussion on TBN about Rotary Cutter size. Try using the search feature at the top of page. Plan on spending a lot of time reading. This brings up a lot of threads. /w3tcompact/icons/eyes.gif
My opinion is that the 5’ is proper size for a 27-2910 tractor.
   / Kubota B 2910 #3
I've been using a 5' Landpride rotary mower for about a year now and have had very similar results to what RonH has had
with his, but mine is a B2400 with 1100 hrs on it. I agree that the 2910 should easily take a 5'. Good Luck !
Rob
Volvo Water Truck, 3306 Cat Engine (A52384)
Volvo Water Truck...
2025 CFG Industrial QK18R (A50123)
2025 CFG...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
550 Tubes Grease Cartridges (A53117)
550 Tubes Grease...
John Deere BD1108 (A50123)
John Deere BD1108...
