Comparison Kubota and JD equivalent to Kioti DK55 or NH boomer 4055-60 ?
   / Kubota and JD equivalent to Kioti DK55 or NH boomer 4055-60 ? #1
NorthernChilli
Bronze Member
Quebec, Canada
NH TD80D, Ford 1320
Hi all,
What would be the Kubota and JD equivalent to the Kioti DK55, the NH boomer 4055-60 or the Massey 1652-60.
Roughly, 5000+ pounds 55-60 engine hp, 12/12 shuttle tranny, cab. Telescopic and quick connect 3ph ends
Thanks, Phil
   / Kubota and JD equivalent to Kioti DK55 or NH boomer 4055-60 ? #2
Hi all,
Thanks, Phil
you can get a kub MX5100 HST 4x4 w/LA844 fel thats 52hp with 44 pto hp.i bought this tractor in oct 2010 for $24,000.
The 5100 doesn't seem to have a cab option. Does it ?
Phil
   / Kubota and JD equivalent to Kioti DK55 or NH boomer 4055-60 ? #4
Phil
The MX5100 really isn't close to what you have specified - No cab, only 3600 pounds with an 8/8 transmission. The price may be right, though!
In Deere the only model that would fit all of your specs would be the 5065M. 65 engine hp, available factory cab, 16/16 PowrReverser transmission, almost 8K pounds with the cab and MFWD - List Price with Dual Rear and Mid SCV's would be $49,455.00 - not including freight and set-up.
The 5083E Limited might work - 83 engine hp, standard factory cab, 12/12 PowrReverser, just under 7400 pounds with MFWD. List Price with Dual Rear and Mid SCV's is $43,189.00 - not including freight and set-up.
You could look at the 4720 as well: 66 engine hp, available factory cab, but eHydro only and around 4400 pounds with the cab. List Price $42,123.00 with Dual Mid SCV's - not including frieght and set-up.
There are a ton of differences between these three models, and remember - all the pricing is at LIST - before any discounts.
   / Kubota and JD equivalent to Kioti DK55 or NH boomer 4055-60 ? #5
The previous poster already mentioned the deere models so I wont mention them.
But I'd look at the kubota M5140 and M6040. Those two are basically the same tractor. The M6040 weighs a tad more and has 16.9 rear tires instead of the 14.9's.
They fit all of your requirements except the 12/12 tranny. The kubotas have 8f/8r.
But the kubota is 5000lbs+ with the cab and have the telescoping arms.
And when compared to the DK55, it has a stronger 3PH by about 500lbs, loader is a bit stronger, and the kubota has the larger 24" front tires that will give a smoother ride and rut less when doing FEL work. The FEL also has two psitions, a power and a height position. In the height position, it will lift about 20" higher than the kioti, if that is important to you.
If you can live with an 8/8 trans, they are worth a look.
2023 John Deere RD40F Draper Head (A53342)
2023 John Deere...
100 GAL FUEL TANK W/ PUMP TOOLBOX COMBO (A52472)
100 GAL FUEL TANK...
NEW Wolverine Skid Steer Bucket Forks (A53002)
NEW Wolverine Skid...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
LEONARD 16 ENCLOSED TRAILER (A52472)
LEONARD 16...
