Kubota air cleaner light?
   / Kubota air cleaner light? #1
daveinnh
Hillsboro, NH
Kubota L4310
We have a Kubota L4310 HST.
The "Easy Checker" air cleaner light is on when I turn the key to "ON" and remains on when running. The engine operates normally.
I changed both air filters last Nov (about 40 hrs. ago) and just installed new filters again today. The problem remains.
Is there a "re-set" switch somewhere?
Any other causes that might activate the light?
   / Kubota air cleaner light? #2
Dave…
You might look at the activation switch, it is screwed into the air cleaner housing. It has a large but weak spring inside… Tap on it, may be stuck. KennyV.
   / Kubota air cleaner light? #3
this is usually caused by the sensor on the air intake failing. it does happen a bit. its the round thing screwed into the intake pipe with the wires coming from it. its near the air filter.replace it. this isn't to unusual for a 4310.
Thanks Kenny & Ozzie:
I bought a new sensor. It rained the nite before installing and while taking the side panel off, the rail appeared to "dump" directly atop the sensor connection. I hope Kubota addressed that oversight in subsequent models.
(I placed a recycled plastic part atop the air cleaner housing to divert the rail drainage.)
1263 (A50490)
1263 (A50490)
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
FRONTIER AV50H LOT NUMBER 114 (A53084)
FRONTIER AV50H LOT...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53472)
2017 KINZE...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A53472)
FIRESTONE 9.5L-15...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
