Kubota accesories
   / Kubota accesories #1
1930
Platinum Member
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
I am gonna pick up my new L2501/loader/backhoe combo in a couple of weeks. Its my first tractor, Ive since learned I need a 3rd function added to run a grapple, I would have thought that the dealer would have tried to sell me everything under the sun including the simonize but no, he even suggested I not buy the backhoe cause of cost.
He has ( as he says ) built my tractor already.
Is it too late to have some accessories added without getting assraped cause now they have to go back and undo some thing they have done to add the loader and backhoe?
I also would like a bucket level indicator added cause Ive read its a good thing to have.
Is there anyplace online that I can get an idea of the cost of these accessories ( just the Ill install it myself out the door price ) so that I can get an idea of what I should expect cost wise before I contact dealer?
   / Kubota accesories #2
Cost of a third function will not change;well worth it.Approximately $900+-.I would have the dealer do it before delivery.Bucket level indicator is pretty simple install.Back hoes are quite expensive;hope you have a lot use for one.If they do install the BH make sure you get the three point hitch parts.
   / Kubota accesories
Thanks, I need to make sure I make a list of the stuff I need to make sure I get
1- three point hitch parts
2- manuals for tractor, backhoe and loader
3- draw bar
4- Ill add to this as it comes to light
Ill use the backhoe for sure, it will pay for itself, Ive still got a few good years left in me
So is it not possible in this online world to not get prices for this stuff before contacting dealer?
   / Kubota accesories #4
You can use the Kubota on line build tool to get a list price for the 3rd function. What the dealer charges is up to them though.
   / Kubota accesories
Dealer is charging me 900 installed for third function. I've done a little research online and that is a good deal. My dealer/salesman has been very good to me.
I'm also getting the bucket indicator and the fiberglass canopy top to keep the sun off me.
   / Kubota accesories #6
Get the worklights. That was one of my biggest regrets with the L3301. With the bucket in travel position you couldn't see **** at night.
   / Kubota accesories
I have some LEDs planned. Thanks
   / Kubota accesories #8
Aside from the items you mentioned, you might want to consider adding the right side grab bar that does not come stock. It is an easy do it yourself install. Also if your dealer is charging you labor to install the bucket level indicator, it too is easy. I did both on my L3901.
I had the dealer add a few things including welding on a couple bucket hooks. Well worth having them do it, and they did so at no cost. Might be something for you to consider. Never know when they will come in handy. :thumbsup:
Are you getting it with R1 or R4 tires?
   / Kubota accesories
R4. If he is charging me for the installs I don't expect it to be out of line.
Good tip on the grab bar, I may get that later
   / Kubota accesories #10
If you know the Kubota part numbers you can look them up in Messicks online parts catalog to get prices for the actual parts...but it wont include labor.
2017 Ford Escape SUV (A48082)
2017 Ford Escape...
2020 MACK PINNACLE (A50854)
2020 MACK PINNACLE...
2016 Dodge Charger Sedan (A48082)
2016 Dodge Charger...
UNUSED 2-Pack Blue Ratchet Strap Set (A50860)
UNUSED 2-Pack Blue...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A49346)
2018 Toro...
