Kubota 7030 Clutch
   / Kubota 7030 Clutch #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
I am about to buy a 7030 and the only fear I have is the clutch. How much can I expect to pay to have the clutch replaced?
It has a FEL and here is no shuttle, so I am presuming it has been shifted alot in 4000 hours.
   / Kubota 7030 Clutch #2
At 4000 hrs you can expect repairs to be needed on many things,,, but it does depend on how it was treated. Do the tires show wear commensurate with 4000 hrs or have they been replaced? Many times the rear tires will tell a tale on how much & how the clutch was used. Do you feel anything suspicious with the clutch when test driving it ? Slips/noises/jerks? If not, tractor clutches are usually pretty tough and it probably is not an immediate concern. How long in your circumstance to put another 1000 hrs on it? When that happens you should plan financially to replace the clutch AND have cylinder kits put in the engine for at least a partial rebuild. Or else resell it. I do not own a 7030 but in most shops these days I'd expect $1200 or so to replace the clutch disk and pressure plate. Not sure if wet clutches are more ?
2020 Mathieu MC210 Azura Flex Street Sweeper (A51691)
2020 Mathieu MC210...
KUBOTA ZD1211 (A53084)
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
