Front-End Loader Kubota 6000E needs a loader
   / Kubota 6000E needs a loader #1
pennyanguy
Kubota/ ariens
I am looking at a Kubota 6000B $WD that has a back blade....It needs a loader for it to work well for me...any idea of what model loaders fit the 6000B
Also, how much wieght can the three point hitch lift?
Tom
   / Kubota 6000E needs a loader #2
I think you mean B6000. That size tractor is really a garden tractor on steriods. Garden tractor size implements is all a 1000 lb tractor can really handle. I know this because I have a Yanmar 1110d which is the same size as the B6000. As far as loaders go a Kwikway or a Johnson Workhorse 10 would work fine on that size tracor. You could see if Koyker makes their model 50 to fit a B6000, that would be expensive though.
The 3 point could probally lift #400lbs with maybe 300lbs of weights on the front of the tractor for counter weight. BTW the B6000s have a backward non standard turning 6 spline pto shaft, this can hinder the amount of implements that could be used on the tractor.
Thanks for the heads up. I am only looking for the unit to do light landscaping on some rental units, ease of transport and size are inportant..they are small 1-2 acre lots. moving trailers and loads of stone, soil, maintain driveways...that kind of thing. a friend has a B7100 HST and its the perfect size...the one I am looking at has a front blade, back blade and a york rake (will never use that)for $2900...what do you think
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51243)
UNUSED FUTURE BOX...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
(INOP) FORD 7710 TRACTOR (A51243)
(INOP) FORD 7710...
