Backhoe Kubota 4672 Backhoe Boom Cylinder
   / Kubota 4672 Backhoe Boom Cylinder #1
jedigene
Bainbridge, GA
Kubota L2350
My Kubota backhoe model 4672 has a badly leaking boom cylinder. My problem is, I can not for the life of me figure out how to remove it. It is mounted inside the boom and I can not figure out how to take everything loose and get it out without damaging hose fittings and etc. Please, if anyone knows how to do this, I would very much appreciate a detailed instruction on how to get it done. Thanks in advance for any help.
   / Kubota 4672 Backhoe Boom Cylinder #2
If you lay it out flat take out the pins and disconnect the hoses off valve body slide the piston out then take the hoses off the piston
Thanks, but I have done most of what you said. Problem is, I can't figure out how to remove the line connections from the cylinder. They appear to go through the boom arm into the cylinder, and too, I can't get the cylinder piston to go forward back into the cylinder.
   / Kubota 4672 Backhoe Boom Cylinder #4
You can't take the piston out with the lines on it
INOP/NON-RUNNING Hyster Forklift (A51573)
INOP/NON-RUNNING...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
NEW Wolverine Skid Steer Bucket Root Rake Attachment 34'' (A53002)
NEW Wolverine Skid...
2019 Freightliner M2 106 Sweeper Truck, VIN # 1FVACXFC1KHKF6139 (A51572)
2019 Freightliner...
