Kubota 4240 non turbo v JD 3720 turbo at hi alt
   / Kubota 4240 non turbo v JD 3720 turbo at hi alt #1
jaj2
I am looking at both K 4240 normally aspirated and JD 3720 turbo. I live at 9000 ft above sea level. Not much air up here, but dealer saying non-turbo not a problem. I need some real life advice. Anyone know how performance on Kubota will be affected?
   / Kubota 4240 non turbo v JD 3720 turbo at hi alt #2
Do to the lack of air both turbo and non turbo will loose horsepower. There should be no difference.
   / Kubota 4240 non turbo v JD 3720 turbo at hi alt #3
Non-turbo will lose more power than the turbo will when going up in altitude, but the turbo may require more maintenance.
Aaron Z
   / Kubota 4240 non turbo v JD 3720 turbo at hi alt #4
I can only tell you that I live at 7,500 ft elevation and work between 6,000 and 9,300 ft elevation. Up to 8,000 ft roughly I find no real noticeable difference, but when I am working around 9,000 ft or higher the turbo does better. My Deere 110tlb is natural and the 4520 is turbo, bear in mind though that the 4520 has more power to start with for its weight.
I would say the non turbl would not be a deal breaker but I would prefer the turbo at your altitude.
Thanks for your thoughts. I wonder if there is an aftermarket turbo normalizer (which in general aviation compensates for high altitude on piston engines) for the Kubota
   / Kubota 4240 non turbo v JD 3720 turbo at hi alt #6
Aaron Z
I'd like to see some printed material on that. I know turbo's require more maintanence at any altitude but I've never heard of that comparison to say that a turbo would loose less at altitude.
   / Kubota 4240 non turbo v JD 3720 turbo at hi alt #7
What a turbo does is cram more air into the cylinders, it is (as you probably know) powered by the exhaust gases and impeller speed is limited by the allowed boost pressure (and as such the air density).
As I understand it, at higher altitudes air is not as dense and as such, the same amount of exhaust leaving the engine will push a larger volume of lower density air into the engine and due to this, the engine will get the same (or almost the same) amount of air at the same density as it would at sea level.
See the following links for more info:
Turbocharger - Wikipedia, the free encyclopedia
Swedespeed Forums: Quick overview of the Turbo concept. (For non technical minds)
http://www.tractorbynet.com/forums/general-atv-utv-discussion/64045-turbo.html
http://www.tractorbynet.com/forums/...ng/48034-jd-turbo-vs-naturally-aspirated.html
Aaron Z
   / Kubota 4240 non turbo v JD 3720 turbo at hi alt #8
What "more maintenance"?
Other then using better engine oils, and/or changing the oil more often, I know of no additional maintenance...and we have plenty of turbo's around....
2019 Freightliner 122SD, Cummins X15 (A47371)
2019 Freightliner...
Ford 9000 Truck (A47369)
Ford 9000 Truck...
2025 Swict 84in Bucket Skid Steer Attachment (A49346)
2025 Swict 84in...
2024 Isuzu NRR 24ft Box Truck (A46683)
2024 Isuzu NRR...
2008 Ditch Witch JT 3020AT (A47371)
2008 Ditch Witch...
Toro Pro Force Towable Blower (A46684)
Toro Pro Force...
