Kubota 3 point problem
   / Kubota 3 point problem #1
wrenchless
L5030
I have L5030 kubota, 3 point wont raise until i raise RPMs a lot, doesnt respond until lever is at top of travel, i have changed both hyd. filter, looked at releif valve, all good, looked at check valves (2) all good, was told to open fill cap and have someone work 3 point lever, i can hear it spraying inside cavity but cant see where, any help will be greatly appreciated
   / Kubota 3 point problem #2
Did you check the hydraulic oil level?
Yes, fluid level was first thought too, i found problem, it wasnt obvious, it was under top cover that holds main valve for 3 point, the return from accessory vales were full of brass that eventually got into check valve in main valve, i took valve completely appart and cleaned it, works great now, my thought are way so many check valves in this system when they are just inches from main releif valve, thanx for the reply
2006 JLG 460SJ Man Lift (A51573)
2006 JLG 460SJ Man...
Ford 1710 Tractor (AS IS) (A50774)
Ford 1710 Tractor...
30' 6-Ring Grain Bin (A50774)
30' 6-Ring Grain...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2012 Ford Escape SUV (A50324)
2012 Ford Escape...
