pan84shov
Tractor was running, but after shutting it off it wouldn't start. Happened once before but after jiggling wires around it started. But this time, nothing happened. I removed the starter and bench tested it, and it was OK. Voltage was good at Battery and at Large terminal on starter. I ran a jump wire from the small terminal on the starter to the battery and it started. Still won't start with the key. Could this be a faulty ignition switch? 120 hours on tractor. I assume the small wire (with a single plug) where I jumped it comes from the ignition switch?
