Loader Kubota 2150
   / Kubota 2150 #1
tessa
winston-salem, nc
kubota 2150
Had broken front hydralic hose, replaced and loader won't lift, bypass switch in correct place, Any ideas
   / Kubota 2150 #4
You bleed it by raising and lowering it and after awhile the air is bled out. Also check the hydraulic fluid level.
   / Kubota 2150
hydraulic fluid ok, raised lever up and down and did not change, making a kind of squealing noise where the lines come in.
2018 Ford F-550 Truck Altec AT40G 40FT Insulated Bucket Truck (A50323)
2018 Ford F-550...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
Kewanee 15' Disk (A50515)
Kewanee 15' Disk...
Pequea HR10 Rotary Rake (A50774)
Pequea HR10 Rotary...
Homemade Head Cart (A50514)
Homemade Head Cart...
