Kubota 122R mower deck belt
   / Kubota 122R mower deck belt #1
okiecraig
Bronze Member
Creek County, OKlahoma
1972 MF 135 diesel, Kubota L3940
Have a 122R that is making a racket when the mower deck is engaged. Want to remove deck to investigate.
How do you relieve tension on the mower deck belt to remove the belt from the engine pulley? this has to be done before you can pull deck from under the platform.
Solved this problem; dropped the deck then pushed it backwards until enough slack to pull belt off engine pully. Now fighting with bolt and nut on tension arm pully which has to be loosened to remove belt....
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
John Deere BD1108 (A50123)
John Deere BD1108...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
5' Box Blade (A50123)
1268 (A50490)
1268 (A50490)
