Tiller KT09-65
   / KT09-65 #1
rgvnaa
edinburg
massey 2605
I just bought a kioti tiller and can't seem to find info on wether its gear or chain driven. The tiller is an older model with a some surface rust. It's probely 10 yrs old. Any help would be great.
   / KT09-65 #2
Welcome to TBN!
Heres some info on your tiller
MODEL KT09-65
Oil bath casting, side cover for chain has a sight glass.
Top Hitch: formed plate-steel formed plate-
Working Width 65"
Discharge popular rear
Maximum PTO-HP 50
Minimum PTO-HP 30
Total Blades 48
Scroll Diameter 17"
Rotor Tube Diameter 3"
Rotor Flange Thickness 1/2"
Rotor Shaft : drop out rotor
Working Depth 7" (5.25"actual)
Machine Weight 586 lbs
Rotor Speeds 264
Side Drive #100 chain high tensile
PTO: heavy cat-05
Extended Torque Tube : standard
Rear Deflector: spring-loaded, flared & reinforced
Hope this helps . . .John
   / KT09-65
thank you very much , does that information applied to older models as well .
2023 LANDHONOR VPC-11-72W VIBRATORY PLATE COMPACTO (A51244)
2023 LANDHONOR...
CAT ENGINE (A51243)
CAT ENGINE (A51243)
LOT LOCATIONS (A52141)
5' X 20' 3/8" THICK STEEL PLATE (2) PIECES (A51244)
5' X 20' 3/8"...
20' Inline Feed Bunk (A50515)
20' Inline Feed...
John Deere 455G Loader (A48837)
John Deere 455G...
