KT-03 Tiller Maintenance
   / KT-03 Tiller Maintenance #1
AaronD81
PA
Kioti CK30
I inherited a CK30 and this tiller, but don't have any manuals for the tiller, nor could I find any info online. Does anyone know the grease points and oil specs? I don't see any grease fittings. Thanks.
   / KT-03 Tiller Maintenance #2
Well finding the grease zerks should be straight forward. A 75w90 or 75w110 gear lube should be satisfactory in the gear box. Drain and fill to the overflow plug. You might find a similar Landpride model as they may have made your unit for Kioti…
Thanks, from looking at other chain driver tillers that oil weight seems typical. Couldn't find any zerks, the left side has the chain drive, right side has a circular cover bolted over a bearing packed with grease. Not sure if it's designed well or poorly, I guess I'll find out. Sticker says made in Italy but only has Kioti labels, couldn't match it to anything and it's at least 15 years old so that would be tough.
New Holland 155 Hay Elevator (A50774)
New Holland 155...
2023 TAKEUCHI TB370 EXCAVATOR (A51242)
2023 TAKEUCHI...
2009 MIE Vessel and 2017 LORT Trl (A50324)
2009 MIE Vessel...
2021 KUBOTA U55-5 EXCAVATOR (A51242)
2021 KUBOTA U55-5...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
