krone 3pt disc mower
   / krone 3pt disc mower #1
farmerjim
new london county,ct
jd h, jd 50, jd2010,jd 790,case530hoe
anyone running a krone 3pt disc mower? was looking at one to possibly replace my old jd sickle. they are the only brand to run a direct pto drive instead of a belt. they also offer a 3pt model w/ a conditioner. just was wondering anyones thoughts on them, i was also looking at the claas 3pt discs as well but, my only worry if i was to get one would be parts, both those brands have dealers that are about 50 miles away. i'd love a moco but some of the fields i hay are a bit narrow, so i think i'll just have to stick w/ a disc or sickle and a seperate conditioner. thats why when i saw the krone and claas w/ the 3pt disc and conditioner i was thinking that would make my life a whole lot better.
   / krone 3pt disc mower #2
A Krone mower is a premium mower and does a fine job. Krone is not the first to use the direct drive system. In the 1970's PZ used the direct drive system. There are 2 disadvantages to the direct drive system vs. the belt drive system. The direct drive system is more expensive to manufacture and requires an extra clutch system & one more gearbox the belt systems does not require. The direct drive system weighs more than the belt system. The reliability is the same for both systems but the direct drive system is more expensive to repair.
   / krone 3pt disc mower #3
I have run both a Claas direct drive drum mower, and recently a belt driven Krone KM 202 disc mower.
The claas is indestructible, the slip clutch with freewheel is wonderful when gearing up on the long lanes and slow down to save sods on the headlands. I put it aside because i felt the blade mounting hooks put my life at risk.
The Krone was priced higher when new, very good machine but there are better machines for less money.
   / krone 3pt disc mower #4
Food for thought,
KISS-- keep it simple stupid. The more parts involved the more chance it will break. thats why belts are still being used. easy to replace.
thats my two bits
   / krone 3pt disc mower #5
amongs other machinery i run a krone am283s (well thats what its called here in australia anyway). 7 disc 3pl mower, it has operated flawlessly, around 2 year old now, about 4000 bales a year (i contract with it). good cut and the quick release blade is an excellent system.
2021 JOHN DEERE 60G EXCAVATOR (A51246)
2021 JOHN DEERE...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
1320 Ford HST, 4wd Tractor (A52384)
1320 Ford HST, 4wd...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
