KOYKER Loader won't lift
   / KOYKER Loader won't lift #1
dogbrdr1
Neosho, MO
2003 Mahindra 2310
I have a YTO 40HP tractor with about 85 hours. It has a fairly new Koyker Loader on it. All of a sudden one day it won't lift...IDK??? I opened all the lines one at a time and worked the controls and fluid squirted out so I can't figure out why it won't lift.......
   / KOYKER Loader won't lift #2
check ALL qd fittings. one may be loose.
if nothing, and your pump is making 'FLOW' out of the pressure port. get a t and put a pressure gauge in line.
post back
post back
I have checked the fittings. How much pressure should it have?
   / KOYKER Loader won't lift #4
most ag setups are around 2500 psi at relief. or thereabouts.... loader valve may be set uder master relief on tractor pump. depends on setup.
   / KOYKER Loader won't lift #5
Is your three point hitch lifting? Put something heavy on it. If it lifts your pump has at least some pressure.
   / KOYKER Loader won't lift #6
Pressure is determined by load.
If you have a hyd gage, plug it into one of the loader lines and activate the lever momentarily.
The gage will show relief pressure.
Check your manual for relief pressure.
ATLAS 10 1/2' DISC HARROW (A51247)
ATLAS 10 1/2' DISC...
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
SKYJACK SJIII 3219 ELECTRIC SCISSOR LIFT (A51246)
SKYJACK SJIII 3219...
2020 KUBOTA RTV...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
