koubota losing power m 6060
   / koubota losing power m 6060 #1
ny
jd 1070
hi i have a 2015 kubota m6060 yhat when i am disking lightly about 3 inches the tractor randomly loes power the rpms drop from 2200 to 900 and engine lugs down almost stalling i called my kabutoa rep and hes said to change fule filter i did vthat same problem it randomly loes power note tractor nas only 147 hrs on it it ran fine a few weeks ago when i used a 3 bottom plow and disked ok then not sure whats wrong any help out there art
   / koubota losing power m 6060 #2
Might be the fuel as well. New filter (again) and drain tank.
   / koubota losing power m 6060 #3
I agree simplest thing to do is change fuel filter and also check for good fuel flow from tank to IP. No matter how low of hours is on tractor fuel can possibly get contaminated.
   / koubota losing power m 6060 #4
Maybe loose debris in the tank that occasionally gets sucked into the outflow?
Maybe also check the air filter cannister for leftover plastic wrapper?
   / koubota losing power m 6060 #5
When was the last time it regenerated? Does it seem to regenerate at fairly standard hour intervals?
last fall around the mid octouber time fram no it doses not see to follow and pater for regening thanks art
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
UNUSED RAYTREE RMT48-48" TRENCHER (A51248)
UNUSED RAYTREE...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A53473)
UNVERFERTH 330 8...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
UNUSEDX-STAR 72" QUICK ATTACH GRAVEL LEVELER (A51247)
UNUSEDX-STAR 72"...
(INOP) CATERPILLAR 320 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
