Oct 1, 2011 / komtsu d37p #1 A al 572 New member Joined Oct 1, 2011 Messages 2 Tractor komatsu d37p working on d37p will not start with key but will buy jumping starter.had starter checked ok new battery reley
Oct 1, 2011 / komtsu d37p #2 Gordon Gould Super Member Joined Apr 1, 2007 Messages 6,657 Location NorthEastern, VT Tractor Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer Do you have any safty switches ? Like a neutral safty switch. Should be in your manual.
Oct 1, 2011 / komtsu d37p Thread Starter #3 OP A al 572 New member Joined Oct 1, 2011 Messages 2 Tractor komatsu d37p Gordon Gould said: Do you have any safty switches ? Like a neutral safty switch. Should be in your manual. Click to expand... thanks Gordon safety switch i will try. also the igntion switch does not turn off unless you pull fuseable out .thanks for answering AL
Oct 1, 2011 / komtsu d37p #4 B Bob Rooks Elite Member Joined Feb 27, 2007 Messages 3,882 Location Washington state Tractor Yuchai Dozer (sold). al 572 said: also the igntion switch does not turn off unless you pull fuseable out . Click to expand... I believe you just solved your own problem. Would have been nice to have known that first. :thumbsup:
