Jan 29, 2012 / KOmatsu problems #1 J juju145 New member Joined Jan 29, 2012 Messages 1 Tractor Komatsu PC 200 What is the PSI for the track motor of the Komatsu PC 200
Jan 29, 2012 / KOmatsu problems #2 Localmotion Gold Member Joined Jun 14, 2009 Messages 425 Location Spain Tractor New Holland 50-86 / Siromer 204S / Case CK-28 / Cat 302.5 / Nissan L35.09 / Nissan Atleon 110 See page 6 of this pdf... http://www.komatsu.com/ce/products/pdfs/PC200_200LC-8_.pdf Hope it helps :thumbsup:
Jan 29, 2012 / KOmatsu problems #3 J_J Super Star Member Joined Sep 6, 2003 Messages 18,952 Location JACKSONVILLE, FL Tractor Power-Trac 1445, KUBOTA B-9200HST juju145 said: What is the PSI for the track motor of the Komatsu PC 200 Click to expand... Relief valve setting: Implement circuits . . . . . . . . . . . . 37.3 MPa 380 kgf/cm2 5,400 psi Travel circuit . . . . . . . . . . . . . . . . 37.3 MPa 380 kgf/cm2 5,400 psi Swing circuit . . . . . . . . . . . . . . . . 28.9 MPa 295 kgf/cm2 4,190 psi Pilot circuit . . . . . . . . . . . . . . . . . . . . . 3.2 MPa 33 kgf/cm2 470 psi
