Komatsu D21A question....
/ Komatsu D21A question.... #1
jimstractors
Pearblossom CA
Iseki, John Deere
I have a chance to get a Komatsu D21A from a friend. Last time he used it was about 6 months ago and it was working fine. Been sitting for about 6 months...Starts and runs great, no smoke, runs great going forward, but when you back up, the right track wants to lock up. I know very little about these, so where should I start?
/ Komatsu D21A question.... #2
I have a Komatsu D20A-6, not sure if our dozers are similar or not but here goes - I venture to guess to start by loosening the right steering break band. Adjust them so that when you pull back both levers, both levers stop at about the same distance out.
When you back up and the track is locking up, does the engine want to stall? If so that would be a pretty good sign that the steering break is catching in reverse, OR someting is binding somewhere.
Now if when you back up and the track locks up AND the engine is not luging then the steering clutch could be out of adjustment or warn out. Go forward, then bury the blade, if both tracks spin then both clutches are OK, if not, that could be a bad steering clutch which is a bad thing.
Another test to check breaks and steering clutch function is when you go forward pull back both levers at the same time to see if the dozer stops and the engine does not lug down. Then release one lever at a time to make sure the steering clutch engages and the break releases. Most Dozers will go in a straight line, even if only one track is actualy being driven - the other track will just follow along.
Larry
Larry....
I will try your suggestions and post my results.
Thanks,
2019 Chevrolet Silverado 1500 LT 4x4 Crew Cab Pickup Truck (A59230)
2019 Chevrolet...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2015 Caterpillar Backhoe (A60352)
2015 Caterpillar...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
(INOP) 1998 FORD F-SERIES FLAT BED TRUCK (A59823)
(INOP) 1998 FORD...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
