Kohler K582 failed head gasket What else while it's out?
   / Kohler K582 failed head gasket What else while it's out? #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
The head gasket failed while blowing snow with the HT23 a couple of weeks ago.
Of course one needs to pull the engine to get away from the sheet metal on this particular application.
Four broken off cap screws extracted later, I'm waiting on parts order. (That and it's been -15 out in the shop ;-)
Complete gasket and seal kit
Starter motor brushes and springs etc.
New piston rings.
Lap the valves, or resurface if required
Anything else that is a "known service item" on these old engines? (1979, 36272 spec)
I'll probably freshen up the paint on the tin work too, it's been looking a bit shabby ;-) Also add a real oil pressure gauge to replace the idiot light.
Ebay offered up an aluminum "dash board" to replace the plastic piece that sheds pieces and edges everytime something presses against it. Plastic does not age well. I'm looking forward to that. It even comes with a key switch!
   / Kohler K582 failed head gasket What else while it's out? #2
If you have the valves out might check the guides or just replace them.
2019 RBR Venturi 380 (A51039)
2019 RBR Venturi...
UNUSED Grey Metal Roof Panels (A50860)
UNUSED Grey Metal...
2016 Ford F-550 Crew Cab Mason Dump Truck (A48081)
2016 Ford F-550...
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
2017 Makita HM1307CB 35lb Demolition Hammer (A49461)
2017 Makita...
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
