Kohler CV22s-67515 wont stay running
   / Kohler CV22s-67515 wont stay running #1
c3c1
DFW, TX
Multi
After sitting for the winter...
I've flushed the fuel line and emptied the carb bowl. The engine will start with a bit of fuel splashed on the carb, but then dies out in few seconds.
Confirmed the fuel pump is pumping by disconnecting from carb and starting.
Confirmed the fuel works by taking that from the pump and using it in the carb for a starter.
It appears to have a fuel cutoff, how can I test that? That part is expensive to just run out and buy.
   / Kohler CV22s-67515 wont stay running #2
Just remove the fuel shut off solenoid and inspect clean and test using 12 v. The plunger should pull back every time you apply 12 v.
There are two red wires with diodes in them. These two merge into one red wire to the solenoid.
You can get the schematic for your engine online
Turn on the ign and test the wire to the solenoid. Should read 12 v.
You should hear a click if working.
Some people just remove the solenoid. It is there for engine backfiring problems. Theory is , cut the fuel, no backfire.
Check the gas cap for venting. Use air and blow back through the fuel line to dislodge any sludge. Check for water.
Check your oil for correct level. You may have fuel mixed in with the oil. If the level is high, then it is either fuel or water. Either way, drain and replenish the oil.
J_J,
Thanks for the info, it got me over the "not sure"s. I found the fuel shut off solenoid non-functional. Disassemble and clean, now its running. Only a slight surging at middle throttle setting.
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2018 FORD TRANSIT T150 CARGO VAN (A54313)
2018 FORD TRANSIT...
2007 FORD F250 XL SUPER DUTY TRUCK (A54756)
2007 FORD F250 XL...
2023 Club Car Carryall 700 Utility Cart (A54811)
2023 Club Car...
