Kohler Courage Pro 25HP low power problem
   / Kohler Courage Pro 25HP low power problem #1
jccndakota
Franklinton NC
1954 John Deere 40, 1958 John Deere 520, 2018 John Deere 5075E
Our 2012 Ariens Max Zoom has the Kohler Courage Pro 25HP engine, 380 hours. Last fall it developed a bad idle, high rpm miss and was down on power. This year I took it to the dealer for a spring service.
The manual said it was due for a valve adjustment so I asked for that also. When we got it back the condition was the same. So it has new fuel filter, plugs, air filter, etc. It fouls plugs pretty fast and has no adjustment on the carb. So I ordered a new carb from Kohler and put it on. It has idle adjustment and idles better. High rpm miss is still there. I decided to check for a vacuum leak as if it were a V8 Chevy. It doesn't respond to putting my hand over the carb opening so I put a rag into the carb opening with the engine running. It kept running so it seems to have a big vacuum leak. The intake manifold looks to be some kind of two piece plastic unit. It's hard to tell if it has a crack because of the design. Kohler sells it for $47.00 so I'm thinking of getting it. Does anybody know if this is common on these engines? I have lots of V8 experience but none with Kohler twins.
Thanks, JC
   / Kohler Courage Pro 25HP low power problem #2
Hi JC. Welcome to the forum! :wave:
I'm going to move this thread over to our Ariens section.
1988 Kenworth W900B Dump Truck with 3406B CAT (A53473)
1988 Kenworth...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
Tafe 45DI (A50123)
Tafe 45DI (A50123)
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
SDLANCH TRACKED MINI LOADER (A53843)
SDLANCH TRACKED...
2015 CATERPILLAR CT660 TANDEM AXLE DUMP TRUCK (A54313)
2015 CATERPILLAR...
