Kohler CH-25 Carb running lean....
   / Kohler CH-25 Carb running lean.... #1
linrick1
Ashburnham, Mass.
Ford 1900, Steiner 430
Hello all, I've been fighting the Kohler on my sawmill. 25 Horse V twin, single barrel Kehin carb, Mikuni pump - went hight through all of it - would not run without about a 1/4 choke at WOT. A lot of hunting with the govenor. Real rough accelerating and died most times returning to idle. No way to adjust the high speed fuel to fatten it up some so I removed the main jet and drilled it out just a little bit...now she runs mint through the whole rpm range, no hunting. Anyone else had this problem with this motor and how did you fix it? Thanks, Rick
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A54814)
2016 Autocar...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2001 Ford F150 (A50121)
2001 Ford F150...
