Kohler 301 Wide base fit a Massey Ferguson 12 Hydro?
   / Kohler 301 Wide base fit a Massey Ferguson 12 Hydro? #1
tractorlady47
1qazzaq1
Hoping for an assist here. I have to replace the Tecumseh HH120 on my Massey Ferguson 12 Hydro. I came across a very good running Kohler 301 wide base but I don't know if the wide base will fit my tractor. Thanks.
   / Kohler 301 Wide base fit a Massey Ferguson 12 Hydro? #2
I did a similar engine replacement on my Deutz Allis 914 Hydro ( made by simplicity, and essentially the same as some MF tractors). I had to install a replacement Kohler 320 shortblock in the frame. The drive shaft in my tractor bolts to the flywheel , so I didn't have to match the engine shaft sizes ( and there are lots of shaft sizes.) The only problem was that the oil pan on the replacement short block did not fit down into the frame. I went on eBay, and bought the only two other size oil pans I could find that bolt to a Kohler 320. One of the two fit nicely , although I had to make a new mark on the oil dipstick to indicate full. The replacement short blocks do not have a balance shaft inside, so they vibrate like crazy ! But, 14 years later, it still runs like a champ ! ( And a Kohler 14 hp. engine puts out a lot more horsepower than a Tecumseh engine of the same power rating , especially if the Tecumseh engine came in a Sears mower!) Good luck with your project !
2016 UTILITY 53FT TANDEM AXLE DRY VAN TRAILER (A50046)
2016 UTILITY 53FT...
275 Gallon Liquid Storage IBC Tote (A49346)
275 Gallon Liquid...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A50046)
2017 FREIGHTLINER...
2003 Ford F-350 Pickup Truck, VIN # 1FDWW36P63EC81092 (A48836)
2003 Ford F-350...
PENDING SELLER CONFIRMATIONS (A50505)
PENDING SELLER...
2014 Ford Explorer AWD SUV (A48082)
2014 Ford Explorer...
