KODIAK KUTTER B160 p.t.o drive to Hydraulic
   / KODIAK KUTTER B160 p.t.o drive to Hydraulic #1
cat 297c
Semmes, Alabama
Cat 299D XHP, Cat 297c, Rayco C140
i found a Kodiak Kutter B160 for dirt cheap wanting to take the pto drive line out that runs the mulcher an put in a hydraulic pump around 50 gpm @5,500psi an run my Denis Cimaf 180d on it:D. Anyone know a Hydraulic Specialists who could tell me wat i need to convert the Kodiak Kutter b160?
   / KODIAK KUTTER B160 p.t.o drive to Hydraulic #2
Do you have 188 HP to run that pump? With those figures, that is what it will take.
I thought the way to measure hyd. hp was Flow x Pressure x .90 ÷ 1714 so
50 gpm x 5,500psi= 275,000 x.90= 247,500 ÷ 1714 = 144.39hhp
   / KODIAK KUTTER B160 p.t.o drive to Hydraulic #4
That 188 HP is derived from Surplus Hydraulics tech help section.
Some people use this one.
# Hp to drive hydraulic pump = Psi x GPM / 1714, and that works out to 160.44 HP.
I am not so sure that there is an efficiency HP loss with a direct drive pump.
1274 (A50490)
1274 (A50490)
Adams Tender / Magnolia Trailer (A53473)
Adams Tender /...
2009-2014 Ford F150 Pickup Bed  (A52384)
2009-2014 Ford...
Makinex Power Lifter (A52377)
Makinex Power...
Adams 6T Fertilizer Spreader (A53473)
Adams 6T...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
