Kodiak brush hog quality
   / Kodiak brush hog quality #1
joe88340
SW Pa
bx2660 m7040
I'm looking for a 10foot brush hog. Only going to mow grass really nothing big. Plan to use kubota 7040. Anybody have any info? Thanks
   / Kodiak brush hog quality #2
I have had a Kodiak HD8 for about 3.5 years. It's been great so far, no issues and seems well built. That said, I do not have a ton of hours on it, maybe 80-100. I did use it for about 15 hours or so a few weekends ago and my fields look great. I do wish it had a smooth deck like some of the more expensive brands, but I keep it in doors when not in use so not a big deal. I'm very happy with it for the price, only regret is not getting the 10' pull type model.
   / Kodiak brush hog quality #3
I have a MD 6'. I think the main concern in buying a cutter is to get the gearbox rating equal to or higher than your tractor's PTO hp. I tore out one on an 8' Mohawk because I didn't follow what I just said.
Other thing is chains and a stump jumper. Stump jumper is a big disc driven by the gearbox with the blades bolted to it. Upon striking something the blades deflect and if a stump or something of the sort, the concave disc just slides over them.
Chains in front a must to keep debris from hitting your tires. Some areas require chains on the rear also, city ordinance kind of thing, but chains on the rear will make your cuttings ball up and come out in lumps, not in a nice smooth windrow.
Some have the frame outside the cutting area and others inside. Outside makes for a cleaner cutting area and I prefer that.
Otherwise I don't find all that much difference for the differences in prices and colors.
Mark
Thanks for the info. Do you know how the off set mowers pull vs. Semi mount. Or any pros or cons. Thanks
Bad Boy 31HP Pro Series Mower (A50514)
Bad Boy 31HP Pro...
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2022 CATERPILLAR 305CR EXCAVATOR (A51242)
2022 CATERPILLAR...
