kobota m 9540 front hub problem
/ kobota m 9540 front hub problem #1
jcarpenter
smiths grove ky
kobota
the left front hub bearing went out in my m 9540, pulled it off took hub to dealer they replaced bearing and seal. put it back together and now its got shavings again and poping again. i flushed out the gear oil before re installing. any thoughts on what is causing this to go out so soon only put about 10 hrs on new bearing. thanks for any help.
/ kobota m 9540 front hub problem #2
sounds like they didn't fix it I would take it back
/ kobota m 9540 front hub problem #3
Hard to say for sure by your description which bearing "went out", and where exactly the debris from said bearing wound up. If your failure was an outer axle bearing, a simple flushing probably isn't enough to clean out all the spaces within the planetary gears. If you had bearing fragments between the gears, ten hours running can produce some expensive damage. The popping your hearing could be chunks of gear teeth.
/ kobota m 9540 front hub problem #4
G'day was preload set properly on the bearing? If it was overtightened then brg could collapse in a short period.
jon
2001 Pierce Pumper Fire Truck (A64556)
2001 Pierce Pumper...
2006 KOMATSU FD80T-8 FORKLIFT (A67148)
2006 KOMATSU...
JOHN DEERE CAT IV / III QUICK HITCH (A64278)
JOHN DEERE CAT IV...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2019 Polaris Ranger Crew XP1000 4x4 Gas Utility Cart (A64557)
2019 Polaris...
