May 18, 2009 / Kobota L3010 #1 W wlhedges New member Joined May 17, 2009 Messages 4 With the loader removed, and the need to pull a haybine with a tractor with no rear remotes, will I hurt anything if I run a couple quick disconnect lines from the joystick, which stays w/tractor to the rear, to operate the haybine cylinder. thanks
May 18, 2009 / Kobota L3010 #2 A art Super Member Joined Apr 10, 2000 Messages 6,798 Location central New York Tractor all makes and models The style valve might make a difference on your side to side but your up down will do fine.
