Knowing what you don't know...
   / Knowing what you don't know... #1
Anonymous Poster
Epic Contributor
Knowing what you don\'t know...
Well, I've had my B7500 for a week and a half now- I've avoided asking questions; for one thing I can find the answer to an amazing number of problems with a search here, and secondly I'm still not sure what I don't know, and what I simply haven't figured out yet. I've put about scant 5 hours on the meter so far- remember that I only have a suburban yard, so I spend more time jockeying it around than working. I'm a long way from being second nature with the FEL, but have had had no major problems and no mishaps, so I figure I'm doing OK.
One of the big dangers of any new "toy" is the initial desire to buy every accessory possible. (On a similar vein, as a young man I was counciled never to embark on any major projects on a house until living there for six months. I ended up tearing out a wall before my purchase offer was accepted...) Anyway, I have managed to come up with a few questions;
<ul type="square"> [*]Am I correct that the hour meter on the B7500 is based on RPM as well? IE, if I'm running at less than PTO speed, it will take more than an hour to show an hour on the meter?
[*]Is there anything that is intended to mount through the slot immediately behind the 2/4 wheel drive lever in the right fender?
[*]In the "Easy Checker" panel, are any of the currently unused positions usable? Besides the center top and center bottom positions, which are blacked out, the lower left position is blue with a lamp icon as if it were for a high beam indicator, and the lower right isred with right and left arrows as if it were for a hazard indicator. Neither is mentioned in the manual.
[*]I have read multiple mentions of the additional lighting circuit that is available under the seat, but wonder how is is activated. Is it also energized by the headlight switch? [*]In the center of the headlight switch is a round 'button" that gives the appearance of being possibly movable. Does any other model perhaps have a control in this position ( maybe a high beam switch?)
[/list]I would like to preserve "stock' appearance to every degree possible, so I am looking for ways to utilize existing locations.
Thanks all!
Re: Knowing what you don\'t know...
TOFKAT,
Belated congrats on the new machine!!! I've been concentrating on the bx forums so much that I just plumb forgot.
Regarding your questions:
The hour meter should be based on a synchronous motor that runs at a set speed when powered. It will rack up hours regardless of engine RPM. So, hours are true hours.
I have a lever opening as well on the bx2200 that is not used (maybe for the outriggers on the bx22??). I keep forgetting to check it out when I'm at the dealers'. I can't answer but am also interested in finding out.
I can't answer the rest. Sorry.
Happy tractoring,
DaveL
   / Knowing what you don't know... #3
</font><font color="blue" class="small">( Am I correct that the hour meter on the B7500 is based on RPM )</font>
I don't know on that model. My B7100 was an electric clock; ran anytime the key was turned on, but my B2710 was based on the rpm like you said; had to have it revved up to PTO speed for it to register an hour in an hour. It shouldn't take you long to watch it and tell which it is.
</font><font color="blue" class="small">( the additional lighting circuit that is available under the seat )</font>
It should simply be a wire with a butt connector on the end. It may be loose and visible or it may be taped to another wire. It's only hot when the key is on, so anything you connect to it will need its own switch unless you want it to always be on when you turn the key on. It's a fused circuit with a fuse in the master panel.
And I don't know the answer to your other questions myself.
   / Knowing what you don't know... #4
Well, congrats. Good that you're playing with your new toy - out in the rain, eh? (Guess we need the water, but I need to plow, darnit!)
<font color="blue"> Am I correct that the hour meter on the B7500 is based on RPM as well? IE, if I'm running at less than PTO speed, it will take more than an hour to show an hour on the meter? </font>
It runs all the time, but I think it is mechanical. It isn't exactly a precision timepeice, though, so it is a bit hard to say. I've tried to use it to determine how long I have to finish something and even at PTO speed it seems to run about 10 minutes per hour slow. I suppose that isn't a bad thing...
<font color="blue"> In the center of the headlight switch is a round 'button" that gives the appearance of being possibly movable. Does any other model perhaps have a control in this position ( maybe a high beam switch?)
</font>
I've wondered about that, too. It doesn't seem to do anything as far as I can tell.
Well, it is a beautiful day today and I'm out of diesel. Time to make a run to get more - and then it is time to mow /forums/images/graemlins/smile.gif before it rains again this weekend /forums/images/graemlins/frown.gif.
   / Knowing what you don't know... #5
Happy tractoring,
DaveL )</font>
I think I remember a dealer telling me that the slot without any levers is for some option that is used over seas and is never used here.
Of course my memory gets worse all the time, but I don't think I woulda picked that up anywhere else, unless someone here on TBN had previously stated that........which of course is also a good possibility!!!
So the mystery is solved....or is it????
   / Knowing what you don't know... #6
The extra slot is for either draft control, (your tractor comes with position control standard), draft is optional or it can be utilized for a rear mount remote hydraulic coupler. The center button arrangement on the light switch is for a horn which is also optional. I don't know about a pigtail under the seat as my 5030 has all accessory terminals used for factory installed options.
Kubota offers up to 3 rear remotes with the power-beyond system. They are a pretty expensive option. 3 remotes will cost you about $1200.00 and that's for the hardware and plumbing, installed yourself.
Draft control allows a rear mounted implement to float with the terrain or maintain a pre-set depth without re-adjusting the implement height. It's useful for farming but for the suburban owner is useless.
Daryl
Forage Services, L.P.
Re: Extra slot - on my BX2200, there's an empty slot that has symbols that appear to depict a movable top link.
Regarding the B7500,
<font color="blue"> your tractor comes with position control standard </font>
Does the B7500 have position control as a standard item? I know it didn't in previous years.
The "narrow' version, B7500DTN, does have position control standard. Neither of the "regular" versions, B7500DT or B7500HSD, do, nor is it listed as an option. With my limited experience, though, I would be interested in it. Has anyone tried retrofitting it using the parts from a DTN? It appears to utilize the same slot, but in the drawings in the manual, a couple of unidentified parts are visible at the front and back of the slot. I suspect that the front one, which appears to be a knob, sets the lowering limit, as the implement lowering limit adjustment specified in the manual specifically excludes the DTN.
<font color="blue"> Has anyone tried retrofitting it using the parts from a DTN? </font>
Just did a search on position control and found this post....
<font color="blue"> The dealer finally got back to me this week about retrofitting the position control from a B7500DTN to either a B7500DT or the B7500HST.
It can be done, but the problem is that all the PC "parts" are different. This means that the cost of the parts alone is about $2500 (no labor, etc.). He appologized for taking so long to investigate. The problem was that the DTN is new enough, and "special" enough, that tracking down the drawings took a little while. He is also kind of busy...
At any rate, it is possible to retrofit this PC, it's just rather expensive to do it.
The GlueGuy
</font>
2008 Doosan Mega250-V Articulated Wheel Loader (A52377)
2008 Doosan...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
2022 Ford Explorer SUV (A51694)
2022 Ford Explorer...
