knocking noise
   / knocking noise #1
nosaj2
none yet
I know this is a long shot. Can anyone make an educated guess what this knocking sound is? Brand new Branson 2515 less than 10 hrs.
   / knocking noise #2
I definitely hear it.
10 hr.s eh? Have you gone over your rig and tightened every nut/bolt that you can see/find?
Greased every grease nipple (zerk)?
If it moves, but doesn't have a grease nipple, given it a shot of lubricant?
Confirmed the torque on the wheel lugs?
Ensured that the fluid levels (oil/hydraulic/coolant) are topped up?
   / knocking noise #3
My NH Boomer made a similar noise and it was the muffler starting to come loose at the engine manifold. Torqued and never came loose again.
   / knocking noise #4
Interesting that you shared this. I have the same exact noise, but mine goes away if I press the clutch. With yours being an hydro, you don't have a clutch, so whatever causes the noise shouldn't be related to a clutch.
This was actually discussed in this thread: https://www.tractorbynet.com/forums/century-branson/428210-branson-throw-out-bearing-concerns.html
I have a video of mine, doing the noise. It's more noticeable at higher RPMs. At first, we thought it was clutch related because K5's Branson is also Shuttle shift, but after checking your video, I guess it's not.
Anyway, I'm a bit over 230 hours, most of hard use, and so far I haven't had any problems with either the clutch or the engine.
   / knocking noise #5
Mine is definitely the throw out bearing. It only makes the noise when I push the clutch in to stop. I have no idea what is making that sound on your tractor. Interesting.
   / knocking noise #6
My 2400H has clutch that is used to engage & operate the PTO. Does the 2515 have this also?
Clutch also removes drive power to the HST
   / knocking noise #7
Sounds like a diesel to me. If you don't like it, get a tractor with an Isuzu diesel or one with a diesel similar to what's in a VW TDI. Have an Isuzu diesel driving our Central Maine generator. It sounds like a gasoline engine. So did the VW TDI.
Ralph
   / knocking noise #8
Ralph
It's not the engine sound. It's the rattling sound over the engine noise.
Here is another example at around 1 min mark:
   / knocking noise #9
It sounds more noticable at higher RPM's. Have you looked for anything loose in the engine compartment? Belt, fan hitting shroud etc?
   / knocking noise #10
determine exactly how to make the noise happen and run it in to the dealer. nice its warranteed
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A54607)
2013 PETERBILT 386...
2007 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XL...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A54757)
UNUSED RAYTREE...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
