knocking noise on lt 1050
   / knocking noise on lt 1050 #1
esbwn
Bronze Member
Payne Oklahoma!
Mahindra 2816
got a quick question, what would cause a slight knocking noise when i first start my lt 1050 with the 26hp Kohler Command engine? after it runs for 5 mins, the noise goes away. i have used it for almost 2 yeas and 90 hrs. any ideals? thanks
   / knocking noise on lt 1050 #2
If it's still under warranty, I would have it checked soon. Without hearing it I can only guess. It could be a valve lifter collapsing and noisy until it pumps up. It could be piston slap which lessens after it expands. A bearing knock probably wouldn't go away after warm-up.
Bob B.
   / knocking noise on lt 1050 #3
Is the noise there whether you are at half, 3/4, or full throttle? Does the oil look clean and right on the full mark?
As Bob indicated, knocking sounds are not good.
oil is where it should be. i start it using the choke and at the lowest idle and let it warm up for about 5 mins. if i take it to 1/2 or 3/4 the engine is to loud to hear it. if im thinking right, it has a 2 yr residental warranty. i will probably just take it in. everytime i have tried to get something covered under warranty on a smaller item like mowers, trimmers, tillers, they always find a way to say its not covered.
2005 Wells Cargo CEW202 20ft T/A Enclosed Concession Trailer (A51694)
2005 Wells Cargo...
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2014 Dodge Grand Caravan SE Van (A51694)
2014 Dodge Grand...
