knocking, loud injector, stuck injector repo
   / knocking, loud injector, stuck injector repo #1
BrettFF205D
S. Maryland
FF205D
Engine knocking aerialhunter(Illinois) 8/6/01 11:53 pm
The knocking didn't sound like it was coming from all 3 cylinders,
just one... Of course I didn't let her run for more than 2-3 seconds
before I shut her down....
Anyway, it doesn't sound good......She only has 1600 hours on
her........... Has anyone heard a diesel <running> that had improper
injection pump timing?
If so, could the knocking sound similar to a rod knock? Just a
<wishful> thought Skip
Re: Engine knocking lensheaf( Dixon, Il) 8/7/01 11:55 pm
To change the injection timing , shims have to be added or removed.
Re: Engine knocking efcconstruction(Pasco Wa) 8/8/01 11:33
am
Had a tractor knocked like crazy thought it was going to blow, just a
bad injector. I would replace that first!!
Re: Engine knocking aerialhunter(Illinois) 8/8/01 7:11 pm
Yeah I've limited the bangin' to an injector, thanks to everyone's
help.
Now, I've removed the injector retainer and fuel line and am trying
to figure out if the injector is "pressed in" (not actually pressed
by slid in) or threaded??? How in the heck do you get it out of the
block? Thanks in advance,
Skip
Re: Injector removal cajundoctor_70711(Albany, La.) 8/9/01 9:49 am
Hi, One method that worked for me on GM generators is to just loosen
the injector retainer but don't remove it. Then crank the engine once
of twice and the compression should loosen the injector. Now just
remove the retainer and take out the injector. Woody
Injector removal and who has the best $ aerialhunter
(Illinois) 8/9/01 9:29 pm
Thanks! What a great idea. I'll try it tomorrow.
Now, who has an injector for a 1989 276D at a reasonable price? Need
one ASAP! COD would be nice too....
Thanks, Skip
Re: Injector removal and who has the bes roger_scotty
(Colorado) 8/9/01 9:53 pm
Talking to the repair guys at the local Yanmar shop, they tell me
that sometimes the injectors are "glued" into position by caked-on
carbon deposits. They also say that the carbon deposits can make it
hard to get the injector out even when it is loose enough to rotate.
They don't look forward to the job of removing stuck injectors.
Thanks to Dave, I have a list of Yanmar factory tools. The "injector
remover" is nothing more than a handle with a M14 thread on one end.
It is screwed into the fuel line hole and I would guess that it just
gives you the leverage to pull and rotate that injector. good luck
Re: Injector removal and who has the bes lensheaf( Dixon, Il)
8/10/01 12:39 am
Contact me at sheaftractor@c... if you want a new injector
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
2017 TOYOTA TUNDRA (A52472)
2017 TOYOTA TUNDRA...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
