Hello Knightrider955. I think that you have an ejector problem. The reaso that your rain cap banges, is because it just mised, and closed. When it fires it flyes open. To test. Crack one enjector line at a time. When you crack an enjector and it makes no difernce, it's the bad one. All the rest will make it run worse. If you have white smoke at low speed or light load, who ever ground the valves may have exceded the recesed hight of the valves.[ground them down too far] There is usely only about .025 to play with. The so and so that did my head did that, so I have white smoke at low speed, or load.
David-Davies
