Oil & Fuel KM 454 fuel filter assembly retrofit
   / KM 454 fuel filter assembly retrofit #1
Ronny_Clark
Lake Charles , La.
Kama 454
Has anyone ever removed their stock fuel filter assembly and replaced it with a more common type? I am considering removing the crappy fuel filter head assembly and replacing it with a Racor 220 series fuel/H2o seperator. It will bolt right up where the old filter assy was and all I have to do is plumb it up. Only issues I can think of is flow capacity etc... The racor will handle 175 gal/hr so it is plenty. Still trying to figure out which oil filter assy I can retofit to work on the KM454. Any thoughts appreciated.
Ronny Clark
   / KM 454 fuel filter assembly retrofit #2
Ronny if you do move forward with the repalcement please let us know how it turns out and any complications you had ... I'd consider following suit .... Scozz
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
PALLET OF MILITARY STRAPS (A51248)
PALLET OF MILITARY...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
JOHN DEERE 7210R LOT NUMBER 144 (A53084)
JOHN DEERE 7210R...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
