Tiller KK oil / grease questions
   / KK oil / grease questions #1
coloradotrout
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
Just bought the TG60 new at TSC (Countryline). Some had mentioned it comes dry, but I only put 16oz in the pto gear box and 16oz on the side gear box. Current manual on KK site says it come with gear oil in it, but no grease. 16oz in the pto box seemed to me to be about 1/2 full as specified. 16oz in the side box did cause it to overflow. I had some mobile 1 synthetic grease for the outer bearing. I put in about 30 pumps before I ran out. The manuals says Type II grease. I used Rotella 85w140 gear oil.
Q1 -- Is the gear oil I used good? Mostly it surprised me that it only took 16oz in each.
Q2 -- Is the grease I used good? I'm not sure what type II is.
Called KK.
In late 09 they started putting some gear oil in the boxes. So it should only take a bit to top them off. I need to drain out the side gear box to where it's just weeping a bit.
As for the outer bearing -- tech said to put in 15 shots of grease, and then 1-2 shots thereafter. I have about 30 I'd guess, so it may leak out the seal, but he didn't seem to0 worried about it.
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
2009 GREAT DANE 53FT REEFER TRAILER (A52141)
2009 GREAT DANE...
White 2-55 Loader Tractor (A50514)
White 2-55 Loader...
New Holland T5060 Tractor (RIDE AND DRIVE) (A50774)
New Holland T5060...
